The dryer motor keeps shutting off but the motor does not get hot.If I turn the dryer drum by hand a couple turns it will restart but shut off agin in a few min.Could built up dust or lint in or arond the motor cause this?
possible. sounds as if motor is failing. also clean out duct hose from back of dryer to out side,
