MICHELLE1996
#1 Posted : Sunday, April 4, 2010 4:55:25 PM(UTC)
MICHELLE1996
My washer will fill with water, drain, and spin. It will not agitate. We have taken the agitater off, but what do I do now? How can I tell what is broken and what I need to replace? Any guidance would be appreciated.
beavis6880
#2 Posted : Sunday, April 4, 2010 6:39:50 PM(UTC)
beavis6880
Just to clarify, are you sure it spins, or you think its spinning. Did you physically see the drum spinning.
MICHELLE1996
#3 Posted : Sunday, April 4, 2010 7:00:37 PM(UTC)
MICHELLE1996
I know it is spinning. When the spin cycle starts and I open the lid, I see the drum spinning (before it stops because I opened the lid).
richappy
#4 Posted : Monday, April 5, 2010 2:49:15 AM(UTC)
richappy
Probably a busted coupler, AP3964635
MICHELLE1996
#5 Posted : Monday, April 5, 2010 4:17:13 AM(UTC)
MICHELLE1996
I took that part out and it appears to be fine. It sits over the large metal piece and it will go back and forth. The metal piece it sits on will not budge. Is that part of the transmission? If so, is that expensive? I ask because the machine is just under 10 years old and if this will be expensive I will look into buying a new one. If I need to call the repairman it will get expensive in a hurry.
richappy
#6 Posted : Tuesday, April 6, 2010 3:13:16 AM(UTC)
richappy
Pull the agitator off, remove the front panel, and move the motor pulley ( one way agitate, the other spin) in the agitate direction. Have someone hold the plastic coupler. If it fails to turn back and forth, remove the coupler and check the tranny spline. If it moves back and forth, you have a stripped coupler, if not, a bad tranny.
Guest (6)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
GE washer won't agitate (Washer Repair)
by jgkjak 7/26/2013 1:27:18 PM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
GE washer Won't agitate does everything else (Washer Repair)
by jbryant1105 4/11/2013 7:04:08 AM(UTC)
Ge washer won't agitate or spin (Washer Repair)
by Mit0410 3/22/2012 1:40:13 PM(UTC)
by kw2107 9/9/2011 11:19:11 AM(UTC)
GE washer won't agitate or spin (Washer Repair)
by rockfixer 5/23/2011 12:40:19 PM(UTC)
Ge washer won't agitate spin or drain (Washer Repair)
by Kevin2685 4/18/2011 7:42:21 PM(UTC)
by andolescia 7/11/2010 8:24:24 AM(UTC)
GE Washer won't agitate (Washer Repair)
by Winfield 4/16/2010 6:51:56 PM(UTC)
GE Washer won't agitate properly and can't figure out which part to get. (Washer Repair)
by phin66 1/24/2010 6:56:10 AM(UTC)
ge washer won't agitate or spin (Washer Repair)
by dgdc 2/23/2009 4:27:02 PM(UTC)
Ge Washer Won't Agitate/Spin (Washer Repair)
by cus70 2/17/2009 7:21:04 AM(UTC)
Ge Washer Won't Agitate/Spin (Dishwasher Repair)
by cus70 2/17/2009 7:15:57 AM(UTC)
