gmon123
#1 Posted : Tuesday, April 22, 2008 5:54:08 PM(UTC)
gmon123
Changed the igniter, we now get gas flow, but the gas will not ignite, wondering if the new igniter gets hot enough to ignite the gas.
richappy
#2 Posted : Wednesday, April 23, 2008 3:29:34 AM(UTC)
richappy
It is rare the gas will not ignite! You may have mounted the new igniter too far from the gas ports, or your regulator is defective and causing a weak gas flow.
Also, make sure the voltage to the igniter is 115 volts.
If everything checks out ok, I would call a pro. to look at it. You might lite the gas with a match and check for gas purity by observing the flame.
gmon123
#3 Posted : Wednesday, April 23, 2008 6:58:22 AM(UTC)
gmon123
Thank you richappy, I installed the igniter backwards, now it's fine. Thanks
