lisiepug
#1 Posted : Friday, April 18, 2008 2:42:49 PM(UTC)
lisiepug
I keep finding a puddle coming out from under the fridge, I have searched different repair forums to figure out what it is and I'm assuming it's the drain pan. I checked the hose and it doesn't appear to be plugged, the drain pan just seems to be full of water and not evarporating. Please help!
kayakcrzy
#2 Posted : Saturday, April 19, 2008 6:32:27 AM(UTC)
kayakcrzy
Take a look inside the freezer on the bottom, and see if there is a ice build up. If so the freezer drain is clogged. If you need me you can reach me at my website at ApplianceEducator.com Tom
glen65
#3 Posted : Saturday, April 19, 2008 8:26:24 AM(UTC)
glen65
As kayakcrzy recommended earlier,
check to see if you have ice build up
in the bottom of the freezer. If you don’t then
you have a leak. Here are some things to check.
1. Check and make sure the drain tube is properly
positioned over the pan.
I’ve ran into a number of cases where the tube
was draining directly onto the floor rather than into the
pan itself.
2. There are two pieces to the drain. (see number 5 and
7 in pic below)
Check to see if the drain tube #5 is properly connected
(or seated) over the drain piece that comes from the cabinet #7.
I've ran into some cases where the tube was mounted but not
connected to the other piece of the drain.
UserPostedImage
3. The plastic drip pan - (check it close) it may appear fine
at a glance but could have a hairline crack someplace.
I’ve done plenty of follow up calls after others to find that this
was the only problem all along.
4. The drain tube,
Check it thoroughly – It could have a crack someplace
allowing the water to drain or leak to the floor
before it reaches the drain pan.
5. Plugged drain tube,
Usually this will case the water to back up into the
freezer section which will cause ice to form on the
bottom. However I have ran into a few occasions
on some drain setups similar to what you have
where the drain would become restricted and would
leak at the joint where the pieces join together.
It happened on units where the pieces weren’t
actually clamped together using any sort of
external clamp. This would cause the water to
skip the drain pan and leak on the floor. I wouldn’t
exactly bet money on this as being the cause but
if your having trouble locating the problem then it
I would make sure to check it anyway to see if there
is an actual restiction in the line.
Hope this helps.
lisiepug
#4 Posted : Saturday, April 19, 2008 12:02:09 PM(UTC)
lisiepug
Thanks for all your suggestions. Well there is no ice build up in the bottom of the freezer, and the tube is in the correct place. Before I have my husband search all the other things, I'm quite certain the water is coming from the drain pan just being too full and not evaporating, I also think there might be a crack in the pan like you mentioned cause it was wet under the pan itself. So is it possible a leak in the places you mentioned would leak into the drain pan causing it to overflow?
glen65
#5 Posted : Saturday, April 19, 2008 2:34:22 PM(UTC)
glen65
When the unit defrosts itself it doesn’t put out enough
water to overflow the pan. If the pan is overflowing then
the water may be coming from some other source.
This unit has chilled water and an ice maker so it’s possible that
one of the supply lines coming from the water inlet valve runs
above the defrost pan and is leaking which could cause the pan to overflow.
lisiepug
#6 Posted : Monday, April 21, 2008 10:14:46 AM(UTC)
lisiepug
Thanks for all you help I appreciate it.
Guest (5)
Viking VCSB5482 - Water in drain pan not evaporating (Refrigerator & Freezer Repair)
by natsibley 3/24/2019 6:26:08 PM(UTC)
