woodzee61
#1 Posted : Sunday, April 20, 2008 6:15:57 AM(UTC)
woodzee61
The freezer side keeps frosting up.I have changed the defrost heater and the defrost thermostat. that did not work So i changed the main board/timer. that did not work either. I have tested everything again.
I have continuity at the heater and at the thermostat.froze or un froze.The heater looks like it has never been on. Were do I go from here.
Desperatly needs help The refrigerator is in the five to ten year range
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
