YellowJeep
#1 Posted : Monday, March 22, 2010 6:44:33 PM(UTC)
YellowJeep
My Quiet Partner 3 Dishwasher is not running. The Soak&Scour button is flashing rapidly. I think it flashes 18 times, hesitates then repeats. I have cut power to the machine for at least half an hour but it does the same thing when I flip the breaker back on. I've had this issue before but I can't afford to bring a repair guy. I can follow directions fairly well. What can I do?
GU2400XTS1
#2 Posted : Tuesday, March 23, 2010 1:11:29 AM(UTC)
I think you are missing a P.
The followings is for an XTPS1 not a XTS1 as given.
Replacement parts for WHIRLPOOL GU2400XTPS1 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Often this is a stuck key (always closed).
Usually trouble shot by checking the keyboard with a meter to confirm this.
If the keyboard checks out OK then it is probably the control board but it is still a bit of a crap shoot.
YellowJeep
#3 Posted : Tuesday, March 23, 2010 7:04:04 PM(UTC)
YellowJeep
Thanks for the links. I actually already have that tech sheet. Most of it is Greek to me. If it's the Control Board then this piece of crap is going to the curb! I'm not sinking anymore big money into this thing. I've already spent as much fixing it as I could have spent on a new one.
How can I test if the button is stuck? I have a good meter. It's the Soak and Scour button thats flashing.
#4 Posted : Wednesday, March 24, 2010 1:31:36 AM(UTC)
[COLOR="Blue"]How can I test if the button is stuck?[/COLOR]
Looks like Soak & Scour is P1-11 and P1-3, see the tech sheet.
Remove the ribbon cable from the control board.
Place the positive lead of the meter on P1-11 and it's negative lead on P1-3.
Use a fairly high meter scale, 20K should do it. If not try 200 K.
You should see the ohms drop when the key is pushed.
I am not sure what the ohms reading will be.
So try this on a good key (normal or start) so you can see what to expect.
I do not know how much electronics you know so this may help explain things.
The reason it is important to have the meter leads used noting their polarity is that you are measuring across the switch and a diode in series. A diode only passes current in one direction. So if you use the meter leads opposite to that shown when you push the key nothing will happen as the diode is basically open.
I hope I explained this OK.
YellowJeep
#5 Posted : Wednesday, March 24, 2010 5:48:01 PM(UTC)
YellowJeep
Ok, I see where it says the P1-11 and P1-3. I never would have known what that meant. So thanks.
It took me a while to figure out how to figure out which end was P1-1. (It's labeled on the board at the base of the piece that the ribbon plugs into.) I'll try it tomorrow when I have the tester.
If I'm fortunate and it is just a stuck button how can I fix it?
Thanks for your help!
#6 Posted : Thursday, March 25, 2010 1:08:56 AM(UTC)
I would not say fortunate as the only way to fix it is to replace the keypad (console assembly)
Guest (5)
