jherman
#1 Posted : Saturday, July 28, 2007 9:11:50 AM(UTC)
jherman
The dryer door does not stay closed after my young son layed on the door. To close it I have to close hard then it still pops open.:mad: I have to duct tape it to keep it closed.:p It appears as though the hinges are bent. I have ordered and received the correct replacement hinges, but can not figure out how to replace them. When the screws are removed from the hinges and door to remove the hinges, there appears to be a spring that is holding the hinges inside the cabinet. What else do I need to do to remove the hinges and how to I remove any parts that I have to, etc. I appreciate any help I can get. :confused:
Thanks,
J Herman
ApplianceJunk
#2 Posted : Saturday, July 28, 2007 2:07:26 PM(UTC)
ApplianceJunk
To remove the door springs you just take the bottom front cover off of the dryer.
There are a couple clips towards the top corners that you can release with a flat blade screwdriver.
Once you get that bottom front cover off you will see the springs and what you need to do.
woodcut
#3 Posted : Friday, March 19, 2010 9:20:02 AM(UTC)
woodcut
Thanks Appliance Junk. I had the same problem as jherman. Now it's fixed. I just wanted to note that the clips that you were talking about on the lower door need to be pressed down, not up. I spent the first 15 minutes trying to lift them up with a flat head screwdriver!
