Morning all. I've got a Sharp Carousel, R510AK. We purchased it for Christmas 1999. Aside from the age, all looks fine. Over the past few weeks, I've been smelling electrical burn, and due to my being on my laptop at the time, I had thought it was the laptop. However, yesterday, I went to warm up some leftovers and I noticed it was louder than normal, and after the timer was complete, I pulled my food, and it was as cold as though I'd just pulled it from the fridge. Upon reading a post by QTip, I see he too had no heat problems with his r1660. I've pulled the cover offand all looks perfectly fine. I.e., no appearance of burnt wiring sheathing, etc..... My first thought are of the magnetron due to the noise level. However, an electrical burn makes me question that it's something else entirely. Part number: R510AK
I was going to post two photos of the guts, but the insert photo tool only allows for weblinks to online photos. sigh.....
Well, I see this one garnered 40 views, and not one response. I can only guess that this means it's a new one, that's not been experienced before, or perhaps my explanation was not good enough. Either way- this post is resolved. I came home this evening, to find that we bought a replacement. As such, like any good tinkerer, I completely disassembled the device, and tossed what I didn't want to keep. The chassis, door, capacitor, transformer, antenna-module (MW generator?), and wiring. If anyone needs parts for their unit, and it takes the same as mine, post back to me, and let me know. I kept the timer-circuit board/face plate, the microswitch plate, rotary motor, fan/motor, a few sensors, and a light bulb/mount of some kind. It's the one that sits behind the portion of the chassis with all of the little 1/8" holes. You'll of course require your own wiring/skills. As I said- the only thing this unit no longer did was heat the food. I checked the transformer and it smelled the worst. I also looked at the magnetron and it smelled pretty wicked too, so I tossed them both. I could not ascertain whether either was actually defective or not, but I figure that 10 years 4 months is a darn good run with that thing. I can be reached at heb113@charter.net if you want any of the parts.
