I see a mounting plate on the parts diagram, how do I remove the microwave? Lift and remove, remove screws first ? If screws need to be removed, where are they located?
You'll need help handling this. It isn't really heavy; but it is a bulky load for just one person. Two or three screws hold it to the cabinet. They're located inside the cabinet and go through to the microwave oven. Then it tilts downward in the front and lifts off a lip on the mounting bracket. Reinstallation is reverse. Don't forget to unplug it first.
