ACH
#1 Posted : Thursday, April 17, 2008 12:40:06 PM(UTC)
ACH
I replaced the Bottom heating element as it was burnt out. Now the Oven takes too long to heat up. The oven was working fine until the element burned out. Any ideas?????
Andy
misterfixall
#2 Posted : Thursday, April 17, 2008 6:03:40 PM(UTC)
misterfixall
is new element getting red
ACH
#3 Posted : Saturday, April 19, 2008 8:45:13 AM(UTC)
ACH
The element is not getting Red Hot. I have checked all the connections and notice that the wires for the element go through the Circuit Board. What voltage should I have and the element. Yellow and Red/Wht wires?
misterfixall
#4 Posted : Saturday, April 19, 2008 11:14:21 AM(UTC)
misterfixall
if you are not getting 220-240 volts coming from board if both wires go to board ,you need a new board
ACH
#5 Posted : Saturday, April 19, 2008 3:45:06 PM(UTC)
ACH
So if I take my volt meter to the 2 terminals I should have 240 volts? correct
misterfixall
#6 Posted : Saturday, April 19, 2008 3:55:37 PM(UTC)
misterfixall
if those 2 wires go to the bake element ,yes you should
gearhead1218
#7 Posted : Saturday, April 19, 2008 6:37:26 PM(UTC)
gearhead1218
Have you got 220 volts to the unit?
When that element blew it may have partially popped your breaker. Clock and oven lite runs on 110 volts. I'm not saying your clock isn't bad, the element may very well have taken your clock out, but check that very basic thing before going any further.
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
Belarus Orlando123 4/20/2024 10:55:35 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Need help with diagnosis - bake and broil not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/7/2022 6:29:02 AM(UTC)
Frigidiare Gallery High temp alert. Need help troubleshooting. (Refrigerator & Freezer Repair)
by GregWood 8/28/2022 7:47:25 PM(UTC)
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
need help with model number (Oven Repair (including Ranges and Cooktops))
by onadraw 7/2/2021 10:01:12 AM(UTC)
Need Help With Frigidaire FGHS2631PF4A (Refrigerator & Freezer Repair)
by BrianR1 3/2/2021 1:46:20 PM(UTC)
I need help with literary work (General Talk)
by Fackbey201350 4/17/2020 7:36:42 AM(UTC)
GE WASHER NEED HELP(SOLVED) (Dishwasher Repair)
by Covenant29204 9/8/2019 9:51:57 AM(UTC)
Whirlpool Microwave Door Sensor Part & Diagram? Need help (Microwave Repair)
by ellie0704 4/8/2019 8:26:28 AM(UTC)
NEED HELP replacing THERMISTOR & FUSE assembly (Washer Repair)
by leastam 1/28/2019 2:06:26 PM(UTC)
