WAYNE JAROSH
#1 Posted : 17 years ago
WAYNE JAROSH
I Have A Whirlpool Dryer That The Heat Will Not Work After 10 Minutes Of Running. The Dryer Vent Was Full And I Cleaned That Out. I Cleaned The Back Of The Unit Also. I Think There May Be A Hi-limit Switch That May Be Out. If I Let The Dryer Set For 15 Minutes It Will Work Again For 10 Minutes And Heat Will Become Cold. Can Anyone Help?
Wayne
misterfixall
#2 Posted : 17 years ago
misterfixall
turn on dryer .go out side +check for good air exhaust, also kinked venting at back of dryer,it could also be timer contact problem
SublimeMasterJW
#3 Posted : 17 years ago
SublimeMasterJW
Could be a bad breaker.
