SKMP9
#1 Posted : Tuesday, March 16, 2010 11:30:54 PM(UTC)
SKMP9
Well, I replaced the thermal fuse, cycling thermostat, and hi-limit thermostat. The dryer gets warm, but still takes 2-3 cycles to dry a load. Lint filter is clean, no build up in exhaust. Can anyone give me an idea for the next step ?
sidfink43
#2 Posted : Thursday, March 18, 2010 4:47:16 PM(UTC)
sidfink43
Pull out the lint screen and take out the two screws you find holding the lint chute to the top. Then take you back off again and take out the four screws holding the lint chute. Clean it out thoroughly, and clean out the blower and vent to the connection to the outside vent.
If this does not clear things up, your problem is likely in the gas burner system.
SKMP9
#3 Posted : Saturday, March 20, 2010 5:50:45 AM(UTC)
SKMP9
sidfink43, thanks for the answer. That was one of the first things I did was clean the entire chute and system out. After replacing the thermostats and thermal fuse, I picked up the 2 coils that are on the gas valve for the burner. That did the trick ! Thanks again.
sidfink43
#4 Posted : Saturday, March 20, 2010 8:02:17 AM(UTC)
sidfink43
That's what it usually is. thanks for the update
Guest (5)
