fancinan@comcast.net
#1 Posted : Monday, April 14, 2008 11:32:12 AM(UTC)
I'm not sure what the problem is, The washer is leaking large amounts of water from the bottom, I recently replaced the coupling and the problem was a minor leak, now it is major. I think my pump is bad, could this be it? I've checked the bottom hose, it's ok. Thank you, Nancy in Atlanta!
bambiblaster
#2 Posted : Monday, April 14, 2008 6:04:48 PM(UTC)
bambiblaster
Could be the drain hose... tip back and see if you can pin point
richappy
#3 Posted : Tuesday, April 15, 2008 1:41:15 AM(UTC)
richappy
Pull off the outer cover and run the washer, should be able to see where the water is coming from, you might have a loose clamp or a bad pump.
#4 Posted : Thursday, April 17, 2008 7:34:38 AM(UTC)
thank you!
