2 Pages12>
tsmendenhall
#1 Posted : Monday, March 24, 2008 7:42:27 AM(UTC)
tsmendenhall
The ice dispenser in the front of the ice ben, and the shoot on the freezer door continue to "freeze up" so the ice cannot be dispensed.
tsmendenhall
#2 Posted : Tuesday, April 1, 2008 4:58:03 PM(UTC)
tsmendenhall
No one has an answer to this one?
tsmendenhall
#3 Posted : Friday, April 4, 2008 5:05:51 AM(UTC)
tsmendenhall
The ice dispenser has to be defrosted once a week. And ice accumulates in the freezer door shoot.
tsmendenhall
#4 Posted : Saturday, April 12, 2008 1:01:50 PM(UTC)
tsmendenhall
I am trying to keep this active. Does any one have a solution for the problem?
gearhead1218
#5 Posted : Sunday, April 13, 2008 9:14:59 AM(UTC)
gearhead1218
Most likely you need to replace the flapper for the chute. Sounds like it's not sealing to the frame properly and letting air in and causing the frost-up problem.
A common problem and not an expensive repair. The part has also been improved from the original.
tsmendenhall
#6 Posted : Sunday, April 13, 2008 12:47:13 PM(UTC)
tsmendenhall
Thank you for the reply. The model number of the Kitchen Aid
Model Number: KSRS2506WH01
Brand: Kitchen Aid
Is not listed in the index. How do I get a part number for the ice maker shoot flapper?
gearhead1218
#7 Posted : Sunday, April 13, 2008 4:17:56 PM(UTC)
gearhead1218
Where are you getting your model #?
You should be taking it off the data plate located in the fresh food compartment.
tsmendenhall
#8 Posted : Monday, April 14, 2008 7:05:55 AM(UTC)
tsmendenhall
The Kitchen Aid model number seems to be KSRS25OGWH01
The serial number is: SH37339603
Purchased in 09/98
gearhead1218
#9 Posted : Monday, April 14, 2008 12:50:45 PM(UTC)
gearhead1218
Part you're looking for is; AP3595356
I believe your correct model # is KSRS25QGWHO1
tsmendenhall
#10 Posted : Thursday, April 17, 2008 6:20:10 AM(UTC)
tsmendenhall
Thank you for your help. The part seems to be working fine. One question: The older flap had a heater with it. The new one does not. Is that problem?
Thanks again!
Guest (8)
Side by Side's Ice Dispenser freezes up solid (Refrigerator & Freezer Repair)
by huberhouse1886 8/1/2008 12:14:52 PM(UTC)
2 Pages12>
