jy6748
#1 Posted : Sunday, March 7, 2010 5:08:14 PM(UTC)
jy6748
Can a thermal fuse blow just because it's old? I recently replaced the heat element and thermostat but did not replace the thermal fuse. After 30 days I now have a blown thermal fuse and at the same the new heat element coil wire is broken. The thermostat still tests okay per ohm meter. I used the "more dry" setting that I don't normally use when this occurred. Could the old thermal fuse have been too weak or old for the new heat element? I'm replacing the element & t-stat again along w/fuse this time but not sure if I have another problem?
#2 Posted : Monday, March 8, 2010 2:35:10 AM(UTC)
Here your parts incvludes the wiring diagram.
Replacement parts for MAYTAG PYE3200AYW Dryer - Ele | AppliancePartsPros.com
[COLOR="Blue"]Can a thermal fuse blow just because it's old?[/COLOR]
Unlikely
[COLOR="Blue"]
I recently replaced the heat element and thermostat but did not replace the thermal fuse.[/COLOR]
Why did you replace both?
Which thermostat?
[COLOR="Blue"]After 30 days I now have a blown thermal fuse and at the same the new heat element coil wire is broken.[/COLOR]
If the heating element broke and touched the case, the coil can heat and is not controlled by the thermostats and this can blow the thermal fuse.
You will notice that the thermal fuse (Item 5 in Section 6) comes with a hi-limit thermostat. This is because if the main control thermostat's (Item 14 in Section 5) contacts weld together causing an overheat condition the hi-limit should have regulated the coil and prevented the fuse from blowing.
[COLOR="Blue"]The thermostat still tests okay per ohm meter.[/COLOR]
How did you test it? I usually heat the face up with my soldering gun just to be sure the contacts open.
[COLOR="Blue"]
I used the "more dry" setting that I don't normally use when this occurred. Could the old thermal fuse have been too weak or old for the new heat element?[/COLOR]
I would doubt this.
Could be just a defective heating element.
I would check/clean both the vent system and the blower wheel and then run the unit disconnected from the vent to ensure you have good air flow.
Also check the seals in the unit. It actually pulls air over the heating element, through the drum so if you have a large air leak it will suck in cold air and cause the unit to run hot.
Check that the lint filter is not coated with fabric softener residue which can reduce air flow through the system.
[COLOR="Blue"]I'm replacing the element & t-stat again along w/fuse this time but not sure if I have another problem?[/COLOR]
I would replace the heating coil and the thermal fuse along with the hi-limit thermostat.
You could confirm that the heating element broke and blew the fuse by checking the inside of the heater for evidence of it shorting to ground re: an arc/weld mark.
jy6748
#3 Posted : Monday, March 8, 2010 1:13:47 PM(UTC)
jy6748
Unlikely
heat element - replaced because I thought it was old, worn out and not heating well enough and the t-stat because it came with heat element.
Which thermostat?
The one mounted right above the heat element, instructions said to replace to it when replacing the element.
The heat element wire didn't appear it touched anything, I just saw it was broken, I will check for weld marks to see if touched.
I didn't test it right, I just checked for continuity/resistance.
I would doubt this.
I will check the blower, vent is clean
I will do as you suggested and thank you very much for the reply. I answered in above in this color.
Thermal fuse ratings and interchangeability on dryers (Dryer Repair)
by Guest 12/17/2023 10:57:55 AM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Thermal fuse blown repeatedly (Dryer Repair)
by Guest 3/5/2023 6:13:36 PM(UTC)
Thermal Fuse on KitchenAid KDTE304DSS0 (Dishwasher Repair)
by jztjzt 7/24/2022 7:04:23 PM(UTC)
Matag Bravos gas dryer thermal fuse (Dryer Repair)
by Maytag Bravos Fool 11/29/2021 4:32:35 AM(UTC)
Magic Chef thermal fuse equivalent (Microwave Repair)
by bassclef78 10/13/2021 9:40:22 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Electrolux dryer thermal fuse (Dryer Repair)
by Lillydz101 8/14/2019 8:59:05 PM(UTC)
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 10/31/2018 9:02:16 PM(UTC)
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Whirlpool Dryer keeps blowing thermal fuse (Dryer Repair)
by MSUspartan25000 9/6/2017 3:11:10 PM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Whirlpool dryer-thermal fuse keeps blowing (Dryer Repair)
by daddjdom 3/28/2017 9:44:13 AM(UTC)
Kenmore problems/thermal fuse/temp adjustments (Dryer Repair)
by Kruegerk 2/12/2017 5:07:37 PM(UTC)
