tcpr12
#1 Posted : Saturday, March 6, 2010 6:35:34 PM(UTC)
tcpr12
Our GE washer will not go to the spin cycle. All other functions are okay. Need help on selecting a new part. thanks.
sidfink43
#2 Posted : Monday, March 8, 2010 6:14:18 AM(UTC)
sidfink43
Look inside the lower service panel and see if you can find some tech notes that will allow you to troubleshoot the machine.
The likely culprit is your speed control board, but sometimes the door lock assembly is also the problem when it does not confirm that the door is locked, so check it also.
GE washer will not spin (Washer Repair)
by MS104 5/10/2016 4:34:48 PM(UTC)
GE washer will not spin with heavy load (Washer Repair)
by carpe 11/2/2013 3:08:18 PM(UTC)
by Rico Whiskey Delta 9/21/2013 10:10:40 AM(UTC)
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12/18/2012 9:05:54 PM(UTC)
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 3/25/2011 3:02:25 PM(UTC)
GE Washer will not spin (Washer Repair)
by mazdaboss 8/18/2010 6:56:42 AM(UTC)
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 5/11/2010 10:29:14 AM(UTC)
by bfreeman91080 1/13/2010 9:15:50 AM(UTC)
GE Washer will not spin or agitate (Washer Repair)
by casshley 11/6/2009 6:00:06 AM(UTC)
by tcahapw 6/19/2009 7:38:23 PM(UTC)
GE washer will not spin nor agitate (Washer Repair)
by Evans 5/18/2009 1:45:06 PM(UTC)
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 3/8/2009 9:44:10 AM(UTC)
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 1/15/2008 3:14:22 PM(UTC)
by csol147462 11/1/2007 7:37:16 AM(UTC)
