shayis
#1 Posted : 15 years ago
shayis
Dryer won't start and light doesn't come on.
I tested the power all the way to the back of the dryer, power is good!
Tested thermal fuse, good
Tested door switch, good
Reading the wiring diagram I cannot figure out how both the light and motor are not getting power. If the switch works then it seems the light should at least come on. All wiring looks good.
What should I check next?
Thanks for your time in advance, any direction would be greatly appreciated.
Shay
magician59
#2 Posted : 15 years ago
magician59
It is possible that the light is burnt out. Have you tried to start the dryer in different cycles?
shayis
#3 Posted : 15 years ago
shayis
It's doubtful the light went out at the same time the dryer stopped working. It was in the middle of a cycle when it just stopped.
Yes, I've tried all cycles, nothing.
magician59
#4 Posted : 15 years ago
magician59
As for the light, it's just a straight-forward simple system. If the light AND the motor won't work, I would heavily suspect the door switch.
Kenmore Dryer Won't Start (Dryer Repair)
by alan93 12 years ago
kenmore dryer won't start (Dryer Repair)
by juliademaree 13 years ago
by derrickp 14 years ago
Kenmore Dryer won't start (Dryer Repair)
by Greyfus 14 years ago
Kenmore Dryer won't start unless PTS (push to start) button depressed and held (Dryer Repair)
by trp 16 years ago
Kenmore dryer won't start just beeps (Dryer Repair)
by drama 16 years ago
kenmore dryer won't start sometimes (Dryer Repair)
by allen9258 17 years ago
