2 Pages12>
gwburkey
#1 Posted : Wednesday, May 6, 2009 11:35:37 AM(UTC)
gwburkey
When Micro wave door is opened the microwave starts to operate.
Repair history:
Replaced circuit board in 2002.
Micro wave originally purchased in 1997
This is a SpacemakerXL Microwave Oven
#2 Posted : Wednesday, May 6, 2009 1:26:56 PM(UTC)
Remove the top grille, open the control panel and check the door switches. If there is nothing wrong then the control board has to be replaced.
- The part number for the control (smart) board is AP2025946
Here are the breakdown diagrams and Replacement parts for GE JVM1340BW02 | AppliancePartsPros.com
gwburkey
#3 Posted : Wednesday, May 6, 2009 3:59:48 PM(UTC)
gwburkey
Thank you for the tip
#4 Posted : Wednesday, May 6, 2009 4:30:54 PM(UTC)
Clay8191
#5 Posted : Saturday, February 27, 2010 7:35:38 AM(UTC)
Clay8191
I read previous post regarding this topic from 05-06-2009, 03:26 PM by Gene Senior Expert APP Volunteer at http://forum.appliancepartspros.com/microwave-repair/32724-micro-starts-when-door-opened.html . I was able to swing the control panel down exposing the switches. As yet I have not determined how to remove them for closer inspection. Any help there would be appreciated as I would not mind the gamble that these switches are the culprit but if the control board needs replacing would likely replace the unit with a new one as the control board is fairly expensive. If I need to order the switch I am not totally sure I have found the correct part on the schematic diagram provided in previous post. I think it is Switch, door sense Part Number: AP2024337 made by GE ( Part Details - GE Switch, door sense, part number: AP2024337 ) but would greatly appreciate confirmation by an expert like Gene if possible and that both switches are the identical part since I haven't gotten them out yet it is difficult to be sure..
Thank you very much!
#6 Posted : Saturday, February 27, 2010 3:13:02 PM(UTC)
What is the complete model number of the microwave?
Clay8191
#7 Posted : Saturday, February 27, 2010 5:45:07 PM(UTC)
Clay8191
I should have thought to include the model number. Sorry. It is: EMO2000C01BB
THANKS!
#8 Posted : Saturday, February 27, 2010 6:26:56 PM(UTC)
You do not have to remove the switches. Remove the wires from them (draw a picture of their location before you do it) and check each switch for continuation with the door open and close.
The interlock switches (#29 on the diagram) should show the open circuit with the door open and closed - with the door closed.
The monitor switch (#30) should show the opposite readings.
- The interlock switch Part number: AP2024337
Clay8191
#9 Posted : Sunday, February 28, 2010 11:02:00 AM(UTC)
Clay8191
Thank you very much for your assistance. I used my ohmmeter on the switch leads as instructed with switch wires removed testing each with door open and then closed.
With door open: Top switch shows an open; bottom switch shows a short.
With door closed: Top switch shows a short; bottom switch an open.
I think that is what you indicated would be the readings?
madmike208
#10 Posted : Monday, March 1, 2010 5:09:25 PM(UTC)
madmike208
Hi Gene,
I just joined this forum and have been reading quite a few of your posts. You seem to really know your stuff. Can you answer me this. My Hotpoint, model RVM1435WJ01, microwave will stop and reset after approx 3-12 seconds after turning on, I've tried different power settings, different outlets, everything else works including the lights fans etc, just wont stay running. What seems to be the problem?
Guest (8)
2 Pages12>
