3 Pages<123>
jayman7
#11 Posted : 17 years ago
jayman7
Gene,
To make things even more confusing, with the ribbon secured in the board, I now get the F2- E6 error and the panel keys are not responsive. Based on this, per you initial suggestions, I should replace the board?
Thanks,
jg
#12 Posted : 17 years ago
Originally Posted by: jayman7 Go to Quoted Post
...with the ribbon secured in the board, I now get the F2- E6 error and the panel keys are not responsive. Based on this, per you initial suggestions, I should replace the board?
Thanks,
jg
We got back to the very first your post and I believe the first failure suspect is the control panel, not the control board.
jayman7
#13 Posted : 17 years ago
jayman7
Gene,
Ok I will replace the control panel.
BTW is there a part only for the ribbon from the control panel?
Also, can you please send me your address to jrg07@yahoo.com I'd like to send my appreciation to your comments.
Thanks,
jg
#14 Posted : 17 years ago
JG,
The ribbon is a part of the control panel and does not come separate.
Thank you very much! Your words is the best appreciation!
jayman7
#15 Posted : 17 years ago
jayman7
Gene,
Good call, just installed the panel all works fine now. I think it was the ribbon
that was damaged due to the curve/hump from the panel to the board causing it to become brittle over time and connecting wires shorted/frayed. Thanks again,
jg
#16 Posted : 17 years ago
I'm glad you were able to fix it.
jayman7
#17 Posted : 17 years ago
jayman7
Gene,
Another problem. Seem all was ok for 1-2 days. Now I get a long beep and no display. I can turn on/off the light via the panel. Could this be the board now? Your thoughts?
Thanks,
jg
#18 Posted : 17 years ago
Did only the light button respond?
Try to turn off the breakers for a minute.
jayman7
#19 Posted : 17 years ago
jayman7
Other button responded but with double beep.
Same things after breaker on/off 1 min. No display.
Thanks,
jg
#20 Posted : 17 years ago
Looks like the control board died now.
- The part number for the control board is AP3595759
3 Pages<123>
