JEANNIE
#1 Posted : Tuesday, August 28, 2007 6:14:09 AM(UTC)
JEANNIE
The Only Thing That Works Is The Cooktop..
Admin / APP Team
#2 Posted : Tuesday, August 28, 2007 9:26:08 AM(UTC)
Admin / APP Team
Rank: Administration
Is the clock dead?
JEANNIE
#3 Posted : Tuesday, August 28, 2007 11:24:39 AM(UTC)
JEANNIE
No The Clock, Timer, Nothing Works Except The Stovetop
JEANNIE
#4 Posted : Tuesday, August 28, 2007 11:47:27 AM(UTC)
JEANNIE
yes the clock is dead
Admin / APP Team
#5 Posted : Wednesday, August 29, 2007 7:08:38 AM(UTC)
Admin / APP Team
If you know how to use a voltmeter, see if you get 110 volts to the clock (there is really no other way to check, other than just taking a guess).
If the clock gets 110 volts, the clock is bad (click for replacement clock), otherwise it's probably one of the safety thermostats on the back of the oven. This is not an easy job. The thermostats are mounted on the back wall and to check them the oven will have to be removed.
JEANNIE
#6 Posted : Wednesday, August 29, 2007 9:34:03 AM(UTC)
JEANNIE
Just So Everyone Will Know, It Wasnt The Clock/timer/electronic (for 156.00) It Was A Sensor Probe (easy To Install) 28.62 Thanks For The Help.
Admin / APP Team
#7 Posted : Wednesday, August 29, 2007 1:07:41 PM(UTC)
Admin / APP Team
Hmm. That's odd. If the sensor was bad, the clock would still display time or usually an error code. In other words, a faulty sensor does not cut power to the clock...
Either way, I'm glad it's fixed (wasn't trying to sell you a new clock :)).
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 6/5/2015 10:52:55 AM(UTC)
Kenmore Elite Electric Range - lower oven does not work after "self cleaning" cycle (Oven Repair (including Ranges and Cooktops))
by AKJim 11/23/2014 5:19:54 PM(UTC)
Oven does not work; everything else is fine (Oven Repair (including Ranges and Cooktops))
by 9hackler 9/21/2014 5:07:11 PM(UTC)
Upper oven does not work (Oven Repair (including Ranges and Cooktops))
by billhoch77@yahoo.com 6/24/2014 11:25:36 AM(UTC)
Whirlpool oven does not work but burners on top do. (Oven Repair (including Ranges and Cooktops))
by formula2fast 12/25/2012 7:13:16 AM(UTC)
electric oven does not work (Oven Repair (including Ranges and Cooktops))
by pawpawrick 10/8/2012 9:35:37 AM(UTC)
Oven does not work (Oven Repair (including Ranges and Cooktops))
by smodes 8/2/2012 11:08:02 AM(UTC)
whirlpool oven does not work (Oven Repair (including Ranges and Cooktops))
by Alketa 6/9/2011 8:23:05 AM(UTC)
kenmore oven does not work cooktop works (Oven Repair (including Ranges and Cooktops))
by voles 3/9/2011 5:38:56 PM(UTC)
Oven does not work after cleaning (Oven Repair (including Ranges and Cooktops))
by mzarahemla 1/26/2011 5:32:35 PM(UTC)
Oven does not work/heat (Oven Repair (including Ranges and Cooktops))
by karenlu 1/4/2011 8:58:56 AM(UTC)
by esauseda 10/18/2010 11:05:41 AM(UTC)
Oven does not work! Frigidaire/Electrolux (Oven Repair (including Ranges and Cooktops))
by justbarbie 10/3/2010 6:45:29 PM(UTC)
Oven Does Not work UUUGH (Oven Repair (including Ranges and Cooktops))
by Puwata 8/8/2010 10:01:45 AM(UTC)
Viking dual fuel range oven does not work (Oven Repair (including Ranges and Cooktops))
by Ren10 4/22/2010 9:31:38 AM(UTC)
