ssp123
#1 Posted : Thursday, February 11, 2010 3:23:28 PM(UTC)
ssp123
I have a Maytag dryer that I have no problems with...works great. A few days ago my timer would not stop running and would not shut off the dryer. I replaced the timer. Pretty simple process everything marked and wires are color coded. Now dryer will not start. It is getting power...lights are on. No breakers tripped. Again, was running great.
Any help would be great. Thanks
#2 Posted : Thursday, February 11, 2010 3:51:07 PM(UTC)
Replacement parts for MAYTAG LDE9606ACE Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Take a look at Page 5-71, you will see 2 thermal fuses inline with the motor, perhaps one of these is blown, both should be 0 ohms. If one of them is blown then get back to us as you still have to try to figure out what caused it to blow and there are different possible causes.
On your original problem. If the timer was not advancing then unless you measured the voltage across the timer motor and saw 120 volts there is no way to tell if the timer or it's control board is the problem.
ssp123
#3 Posted : Tuesday, February 16, 2010 6:06:50 PM(UTC)
ssp123
Thanks. I had a service man look at this problem today. He checked all of the fuses with his voltage meter. No issues. He ran 110 directly to the motor but it still wouldn't start. He determined that the motor was bad. So I am considering a new washer.
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Maytag Dryer won't start when hot (Dryer Repair)
by MrFrisco 12/9/2012 5:58:05 PM(UTC)
by crmullins 7/9/2012 9:36:41 PM(UTC)
by timmykang 6/23/2012 12:21:08 PM(UTC)
Maytag Dryer won't start (Dryer Repair)
by tmckeithan 11/30/2011 5:07:47 PM(UTC)
by cah14522 2/10/2011 2:43:44 PM(UTC)
Maytag dryer won't start- thermostat question? (Dryer Repair)
by Underdog 1/30/2010 4:43:58 AM(UTC)
Maytag dryer WON'T START ! (Dryer Repair)
by souptafied 5/22/2009 4:25:25 PM(UTC)
Maytag dryer won't start....... (Dryer Repair)
by ShaNene 3/4/2009 8:40:55 AM(UTC)
Maytag dryer won't start Help!!!! (Dryer Repair)
by Dwatts 11/17/2007 9:54:55 AM(UTC)
