rhpeterson1
#1 Posted : Monday, February 15, 2010 5:57:15 AM(UTC)
rhpeterson1
dishwasher is draining as soon as it fills, so within 5 minutes it is empty.
#2 Posted : Monday, February 15, 2010 12:22:40 PM(UTC)
A model number may help others help you.
Also did it used to work OK?
rhpeterson1
#3 Posted : Monday, February 15, 2010 1:01:44 PM(UTC)
rhpeterson1
I believe the model is 8524569. and yes it worked.
#4 Posted : Monday, February 15, 2010 1:13:12 PM(UTC)
Sorry but that does not look like a Kitchenaide model number.
Usually they start with several letters.
Model Number Locator
rhpeterson1
#5 Posted : Tuesday, February 16, 2010 5:15:19 AM(UTC)
rhpeterson1
Sorry,
Model number is KUD101ILBS2
#6 Posted : Tuesday, February 16, 2010 6:32:38 AM(UTC)
I think your model should be KUDL01ILBS2 not KUD101ILBS2
Info below is for the KUDL
Replacement parts for WHIRLPOOL KUDL01ILBS2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
Check that the drain motor Item 17 in Section 8 is getting power when it should not.
If it is then your control board is probably shot.
Guest (8)
dish washer runs with doo open (Dishwasher Repair)
by Guest 4/17/2022 8:59:58 PM(UTC)
Dish washer not cleaning dishes KDTE204EPA1 (Dishwasher Repair)
by Guest 12/15/2021 7:24:01 AM(UTC)
correct orientation of plugs on ASKO D3122 anti flood microswitch. dish washer ? (Dishwasher Repair)
by turbo1600 8/20/2020 8:16:40 PM(UTC)
Whirlpool dish washer WDF110PABB2 Filling but not washing. (Dishwasher Repair)
by KG4MXV 6/15/2018 2:57:20 PM(UTC)
Kitchenaid dish washer leaking from below (Dishwasher Repair)
by chrysrobyn 12/19/2016 6:33:56 AM(UTC)
Dish washer stopped and want finish, all lights off (Dishwasher Repair)
by b.alford002@comcast.net 8/30/2015 11:17:11 AM(UTC)
How to replace motor bearings on Kitchen Aid KUDSO1FLSS1 dish washer (Dishwasher Repair)
by rajfixplumming 3/1/2014 10:33:52 AM(UTC)
Dish washer stops 14 Min in to cycle (Dishwasher Repair)
by Wayne_44 2/6/2014 4:55:37 PM(UTC)
Dish washer no lights on panel stopped mid cycle (Dishwasher Repair)
by 56Gomer 8/18/2013 6:34:28 AM(UTC)
by poloman 8/5/2013 9:38:22 AM(UTC)
by poloman 8/5/2013 9:34:27 AM(UTC)
Dish Washer (Dishwasher Repair)
by jobronie 7/25/2013 3:42:51 PM(UTC)
by everettwayne 6/19/2013 8:19:55 AM(UTC)
Dish washer won't dispense water. (Dishwasher Repair)
by Tom Loszchuk 4/2/2013 5:52:22 PM(UTC)
GE Dish Washer Stops midcycle (Dishwasher Repair)
by mwpresnell 2/8/2013 8:41:24 AM(UTC)
