avellana32
#1 Posted : Sunday, February 14, 2010 10:13:35 AM(UTC)
avellana32
I have recently replaced both the pump and drive belts on my unit, but I am unable to properly adjust the tension on the pump belt. I have moved the pump assembly as far over as is possible, but there is still too much slack in the belt. I've called Appliance Parts Pro to verify that I do have the correct part numbers, which I do. However, the linear length provided on the website for both belts is a half inch smaller than the belts I have received. Is there another way to adjust the tension, or are the belts I received an incorrect size, despite being the correct part number? Any help you could give me would be greatly appreciated.
magician59
#2 Posted : Sunday, February 14, 2010 6:39:28 PM(UTC)
magician59
Maytag washer belts are designed to have some slack in them. This is their way of eliminating the need for a clutch. The spring-loaded motor base takes up the slack when in motion. Unless the belts fall off the pulleys, they're probably the right ones.
avellana32
#3 Posted : Monday, February 15, 2010 4:08:44 AM(UTC)
avellana32
Thanks for your reply. I see the point of having slack in the belts, but right now it think there may still be too much slack. The belt doesn't fall off completely, but it doesn't seem to always turn the pulley either. If the belts I have measured a half inch smaller (like the linear length listed on the website for them) I think that might make all the difference. Weird.
