Interior lamp not functioning. I can't find it in order to identify and order a replacement. Location of lamp is not apparent upon looking inside the microwave. Any suggestions about where/how to find the location of the lamp would be appreciated.
Look at the back of the microwave (on the outside). There is a little door held on by one or two small screws. The bulb is in side. It's a bayonet base appliance bulb. You should be able to find a replacement at any hardware store.
I was really hoping I didn't have to remove the MW from the wall as it is a really heavy sob and it is probably a two-man job; not to mention all the dinnerware I have to remove from surrounding cabinets. I was afraid I would find out exactly what you advised. It is what it is. Thank you very much for your response. Originally Posted by: gregl470 Look at the back of the microwave (on the outside). There is a little door held on by one or two small screws. The bulb is in side. It's a bayonet base appliance bulb. You should be able to find a replacement at any hardware store.
