3 Pages123>
E521585
#1 Posted : Saturday, February 9, 2008 10:15:09 AM(UTC)
E521585
My Kenmore Coldspot is not producing ice. The appliance is about 5 months old. The water is flowing fine. I also just replaced the filter (even though the light was still green). When I open the freezer door there is a red light blinking. The icemaker is on. I could not find any guidance in the user guide related to this red light but I am thinking it may be a faulty sensor?
#2 Posted : Sunday, February 10, 2008 9:32:05 AM(UTC)
Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and monitor the diagnostics status LED on the right side.
Post your findings.
E521585
#3 Posted : Sunday, February 10, 2008 9:54:58 AM(UTC)
E521585
When I press the emitter flapper door the light on the right stays a constant red. If the flapper door is not pressed the red light blinks.
#4 Posted: : Monday, February 11, 2008 10:44:13 AM(UTC)
This test proves there is nothing wrong with the ice maker electronic control.
Due to your fridge is less then a year old and is still under the full manufacturer warranty, I do not think it is a good idea to perform more serious troubleshooting. Also, any attempt of repair from your side will void the warranty.
The best thing is to call the Sears for service.
E521585
#5 Posted : Tuesday, February 12, 2008 4:28:15 AM(UTC)
E521585
Thank you.
ndazone09
#6 Posted : Sunday, March 23, 2008 6:48:10 PM(UTC)
ndazone09
I have a Kenmore Coldspot that is not producing ice. I have never tried to work on anything like this before. How can I check to make sure the water is flowing good, and what else should I check? I really do not have a couple of hundred dollars to call a serice person out. It is about two and half years old. The ice maker stop working about 6 months ago.
JBianca
#7 Posted : Saturday, February 13, 2010 11:28:56 AM(UTC)
JBianca
I am having the same problem but my diagnostic is different when I check the blinking red light. When I push the flap back, it changes from a constant red blinking to two quick blinks - pause - two quick blinks - pause, etc. I'm a renter with a really unreasonable landlord. Is there anything I can do to fix it? Thanks.
#8 Posted : Monday, February 15, 2010 3:46:00 PM(UTC)
What is the complete model number of the refrigerator?
negcashflow
#9 Posted : Thursday, February 24, 2011 10:23:30 PM(UTC)
negcashflow
I'm having a similar problem. The icemaker works fine, as I've emptied the ice box and had it fill up again. But the dispenser itself won't release any ice. It's not stuck and the water dispenser works fine. I also don't hear the rumbling of a motor like I did before when the ice pedal is pressed.
The model is 106.55606400
#10 Posted : Friday, February 25, 2011 1:53:09 PM(UTC)
Does the ice gate open when you depress the ice dispenser lever?
3 Pages123>
