soonerdaev
#1 Posted : Saturday, February 13, 2010 9:27:01 AM(UTC)
soonerdaev
As the title suggests, I have a problem with the subject dryer.
When new, the dryer on highest setting would generate heat sufficient to be felt on top surface of cabinet; now, within the last month or so (?), there is not enough heat to dry clothes. Problem first observed as a sudden absence of sufficient heat, then very long (almost ridiculously long) drying times. Dryer vents through roof, and vent was cleaned last year. Duct work from dryer vent to wall outlet is clear, unkinked, and unobstructed. Breakers are not tripped, and supply cord is undamaged.
I removed the front access panel, turned on the dryer, and observed the heating elements cycle on for perhaps three minutes, then shut off. After several more minutes, they cycled back on for a few minutes, and then off again. They were never on long enough to generate any more than a token amount of heat.
This suggested to me either a faulty thermal limiter and/or a faulty thermostat, but was not sure which was more likely. I eliminated the idea of a fuse given the thought that a fuse would, in theory at least, inhibit heater operation entirely. I did not want to throw money at parts without at least a better idea of what is the more likely issue - thermal limiter or thermostat.
Any suggestions very welcome and appreciated in advance.
Blessings,
David
#2 Posted : Sunday, February 14, 2010 1:26:18 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576801.pdf
[COLOR="Blue"]
Dryer vents through roof, and vent was cleaned last year.[/COLOR]
I would not assume that the vent is still OK as this is the most common cause of your symptoms.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers/vent open fully/clear.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
[COLOR="Blue"]I did not want to throw money at parts without at least a better idea of what is the more likely issue - thermal limiter or thermostat.[/COLOR]
Could be either also may be a grounded element, where only part of the element is heating very hot so the unit cycles too often. Or the element may be running on 120 volts instead of the full 240.
It is unusual but not unheard of for a thermostat, thermal limiter to start switching off at a lower temperature.
Also your thermostat has an internal heater perhaps it is being held on all the time, this would keep the unit in low heat mode. Try different heat settings to see if it makes any difference.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
