snag181
#1 Posted : Wednesday, February 10, 2010 2:47:17 PM(UTC)
snag181
water is leaking out the bottom of the washer cabinet. is there a manual or diagram to see where this might be coming from? all hoses on the outside of cabinet are tight and dry, drain tube seems good, thinming it has to be in the cabinet.
thanks for the help, snag
#2 Posted : Wednesday, February 10, 2010 5:41:48 PM(UTC)
You have to remove the front panel by removing the screws on its bottom in order to pinpoint the water leak.
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for AMANA LWA18AW Washer - Top Loading | AppliancePartsPros.com
