george m
#1 Posted : Tuesday, April 1, 2008 2:48:00 PM(UTC)
george m
how do you remove the agitator to service the transmission tube seal on this model
richappy
#2 Posted : Tuesday, April 1, 2008 3:04:18 PM(UTC)
richappy
There should be a bolt under the cap at the top of the agitator, after you get that off grab the bottom of the agitator and pull off. If it is stuck, put a rope under the agitator and pry it out with a 2x4 with the top of the washer as a pry point.
Go to web site www.applianceaid.com for info on this, this is a big job and I have declined to fix these!
Removing agitator, GE washer (Washer Repair)
by tealbingy 1/28/2011 11:51:33 AM(UTC)
Removing Agitator (Washer Repair)
by dap 9/21/2010 9:00:54 AM(UTC)
removing agitator (Washer Repair)
by gregdcwirth 4/2/2010 5:52:53 AM(UTC)
by rmullar 10/11/2009 2:39:52 PM(UTC)
by james429 11/19/2008 12:25:15 PM(UTC)
Removing agitator (Washer Repair)
by Jeffrey M. Quirante 6/22/2008 12:33:33 PM(UTC)
by Yago 4/23/2008 3:06:04 AM(UTC)
by bubbatippy 1/23/2008 12:04:03 PM(UTC)
