Lazer
#1 Posted : Monday, March 31, 2008 12:47:55 PM(UTC)
Lazer
Dryer will not shut off when puton regular setting
#2 Posted : Tuesday, April 1, 2008 12:21:44 PM(UTC)
Hi Lazer,
Did it heat?
Did the timer advance?
We need as much information as possible.
Lazer
#3 Posted : Thursday, April 3, 2008 11:52:10 AM(UTC)
Lazer
Yes it heats but timer does not advance already replaced timer and thermostat on vent
#4 Posted : Thursday, April 3, 2008 12:06:40 PM(UTC)
Possible the cause of the problem is a clogged vent or a bad blower (#4 on the motor drive break down diagram) inside the dryer.
Here are the break down diagrams for the Maytag dryer Model MDG6200AWW
Lazer
#5 Posted : Thursday, April 3, 2008 12:47:09 PM(UTC)
Lazer
Checked out dryer motor and fan all seams working well also checked duct work not blocked thanks for you help any more suggestions would be greatly appreciated
#6 Posted : Thursday, April 3, 2008 12:49:11 PM(UTC)
Disconnect the vent hose from the dryer and run one or two loads without that hose.
