carlos p
#1 Posted : Sunday, March 30, 2008 9:49:01 PM(UTC)
carlos p
check defrost heater and is good could not find timer
fixtec90
#2 Posted : Monday, March 31, 2008 4:11:09 AM(UTC)
fixtec90
You don't have a timer on your refer. Find main board on back of refer. Find the 2 or 3 wire connector that is marked comp, line, and defrost. Unplug refer. Put a jumper wire from line to def. Plug refer back in. If your heater turns on replace main board. It also a good idea to replace the thermistor located on the evaporator. They're cheap and it will ensure trouble-free cooling until next time it breaks down.
