Scoob
#1 Posted : 15 years ago
Scoob
My evaporator is freezing up not letting the fan blow over the coils to cool the frig or freezer. The fan is ok. What part do I need to order to fix this problem?
Thanks,
Scoob
#2 Posted : 15 years ago
Here are your parts includes a wiring diagram
Replacement parts for FRIGIDAIRE FRS20QRCW8 Frg(v2) / Refrigerator | AppliancePartsPros.com
Can be one of 3 devices
Timer Item 23 in Section 6
Thermostat Item 21 in Section 6
Heater Item 14 in Section 6
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Scoob
#3 Posted : 15 years ago
Scoob
Thank you very much for the information.
Scoob
Evaporator freezing up (Refrigerator & Freezer Repair)
by tbanks204 7 years ago
Fridge side evaporator freezing up... (Refrigerator & Freezer Repair)
by steve1147 10 years ago
