jodidobz
#1 Posted : Saturday, March 29, 2008 8:06:52 AM(UTC)
jodidobz
My washing machine has the accuwash temperature control feature on it, but when the hot water should go in it doesn't. I know the hot water is working because I unhooked the hose from the back of the washer to make sure it wasn't kinked and got sprayed with hot water. (forgot to turn the water off)
Any other suggestions as to why I can only use cold water?
fixtec90
#2 Posted : Saturday, March 29, 2008 8:34:50 AM(UTC)
fixtec90
Tough call. Heres how it works:
Timer sends power to temp switch and switch sends power to the water valve. I'd start by checking for power at the hot water solenoid. If power is present (120vac) your valve is bad. Next would be the switch. Determine which two contacts should be closed when hot water is selected by looking at the wiring diagram. You should have a closed curcuit (continuity). If not your switch is bad. If that tests good replace timer.
I should note this info is generic. I didn't look at a wiring diagram for your washer. I think the three parts I mentioned are the only components on your fill curcuit, but cannot confirm. I hope this helps.
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
