tempo1001
#1 Posted : Monday, March 24, 2008 1:54:13 PM(UTC)
tempo1001
My Signature washer will wash clothes great but will keep on washing right through the drain/rinse and spin cycle until the final drain and spin cycle.
I tried to look up the model number but didn't find anything. The serial number is XC54223469.
The washer said Signature on the control panel but says "Frigidaire" and "White Consolidated Ind" where the model number is written.
If you have any suggestions, please let me know
Thanks for your help:
CORRECTED MODEL NUMBER MWL111RBW2
#2 Posted : Tuesday, March 25, 2008 9:55:51 AM(UTC)
Most likely the problem is a bad timer but without the complete model number this is just a guess.
tempo1001
#3 Posted : Wednesday, March 26, 2008 11:28:10 AM(UTC)
tempo1001
Sorry for the confusion
tempo1001
#4 Posted : Thursday, March 27, 2008 10:52:07 AM(UTC)
What did you mean saying: "will keep on washing"? Be more specific, please.
tempo1001
#5 Posted : Friday, April 4, 2008 9:41:46 AM(UTC)
tempo1001
The washer skips the drain/rinse and spin cycle and keeps on washing until it reaches the final drain and spin cycle
#6 Posted : Friday, April 4, 2008 6:26:54 PM(UTC)
Looks like the timer is a failure suspect.
Unfortunately this part is no longer available. You probably have to look for a new washer.
hammer33
#7 Posted : Sunday, January 18, 2009 1:31:23 PM(UTC)
hammer33
TO whom it may concern, I have a Kenmore Heavy Duty Extra Large Capacity Plus washing machine. Model # 110.22292100, Serial # cm 2937753, Type# 107 . The washing machine goes through the partial rinse cycle then just stops. It does not advance at all. Just stops completely. It happens on all wash cycles, same thing. Could this be the timer or the door lid switch or both? Thanks for any light you may be able to shed on this delima. Doug M.
#8 Posted : Sunday, January 18, 2009 8:36:32 PM(UTC)
Hi Doug,
If it does not drain and spin then the first failure suspect is the lid switch.
- The part number for the lid switch is AP3100001
kyleb
#9 Posted : Monday, March 2, 2009 7:37:27 AM(UTC)
kyleb
I have the same problem as hammer33 above in this thread. How does one discern between a failing lid switch or a timer? My machine stops in the middle of the cycle, on all different washes.
#10 Posted : Monday, March 2, 2009 1:39:46 PM(UTC)
Where exactly it stops? Would it spin and/or drain if you advise the timer manually? What is the complete model number of the washer?
Guest (5)
Washer will not rinse or spin (Washer Repair)
by Ktaka23 4/9/2014 9:11:11 AM(UTC)
washer will not rinse right cloth still wet (Washer Repair)
by bob n jack 5/3/2012 3:23:15 PM(UTC)
Washer will not Rinse (Washer Repair)
by dvidler1 8/7/2011 5:26:37 AM(UTC)
Washer will not rinse (Washer Repair)
by stumpt 3/18/2011 4:24:10 PM(UTC)
Front load washer will not rinse/drain or spin out (Washer Repair)
by haroldlm 12/9/2009 9:15:50 AM(UTC)
washer will not rinse/ new timer replaced (Washer Repair)
by bak 10/22/2009 3:59:59 PM(UTC)
ge washer will not rinse or spin (Washer Repair)
by tmm313psu 10/2/2009 3:48:31 PM(UTC)
by jimbo0555 6/26/2009 5:20:11 PM(UTC)
