Replaced fill value, water coming out good' but does not fill ice maker, ice maker goes through cycle but does't fill with water.
Originally Posted by: janetvee ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Replaced fill value, water coming out good' but does not fill ice maker, ice maker goes through cycle but does't fill with water. have same problem with sub zero ice maker-ice maker-when filled manually it makes ice and dumps when ice is made-replaced two water valves that receive the voltage from the ice maker but valve does not open-water pressure ok-outlet side water line to the ice maker clear. HELP!!
