arcojet
#1 Posted : Monday, March 24, 2008 6:48:01 PM(UTC)
arcojet
Every time the start button is pressed the fuse that is about 1/4 wide by 1 1/2 long blows. I believe one of the wires goes to the motor and the other wire goes up top. Any ideas? thanks
richappy
#2 Posted : Tuesday, March 25, 2008 2:08:04 AM(UTC)
richappy
Look for a short some were. Might be the motor, although rare. I would use an ohm meter and check things.
arcojet
#3 Posted : Tuesday, March 25, 2008 4:30:48 AM(UTC)
arcojet
Checked every thing out and the only thing I can find is there seems to be a direct short to ground on the wire from the fuse to the motor. Is there another switch on the motor that might be bad? The only thing left to do is pull the front off and check it out. I dont want to do that if it is the motor I'll just get another dryer.
