nobull1466
#1 Posted : 15 years ago
nobull1466
Frig has power to it. All lights are on. However, the condenser fan, evaporator fan and compressor are not running. At first I thought it was the defrost timer but after changing it the frig still does not run. Any other ideas would be helpful
#2 Posted : 15 years ago
Replacement parts for WHIRLPOOL ED25PEXHB00 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202204338.pdf
[COLOR="Blue"]
At first I thought it was the defrost timer but after changing it the frig still does not run.[/COLOR]
Did you try advancing the timer cam manually with a screwdriver as it does sound like you are in a defrost cycle.
Looks like a lot of things run through the thermostat my guess would be that the defrost timer will not advance unless the thermostat is closed. Also looks like the unit cycles the compressor, condenser fan and evaporator fan all together.
If advancing the defrost timer did not start up the compressor etc. could be your thermostat is toast.
Refrig Not Running (Refrigerator & Freezer Repair)
by rtrchnj 12 years ago
Amana refrig not running (has power) (Refrigerator & Freezer Repair)
by reidjantz 16 years ago
