skifrk
#1 Posted : Friday, March 21, 2008 12:04:55 PM(UTC)
skifrk
I had a water leak and found a hole in my bellows. Part # 909351. Appliance Parts Pro shipped me the part, (at the best price), and I am trying to figure out how to get the bellows onto the tub housing. Do I have to pull the tub or is access by way of pulling the front cover. THANKS TO ANYBODY WHO CAN HELP!!!
bambiblaster
#2 Posted : Saturday, March 22, 2008 5:03:32 AM(UTC)
bambiblaster
It can be done thu the door opening but is tricky sometimes getting the clamp right.. I usually take the front off... Dont over tighten the clamp that holds it to the tub just snug it...
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore Elite Washer HE 3T (Washer Repair)
by loilanh 5/12/2020 10:08:29 PM(UTC)
Kenmore Elite Washer Baffle Replacement (Washer Repair)
by lkdykens 5/3/2020 8:54:41 PM(UTC)
Kenmore Elite washer, no power to drain pump? (Washer Repair)
by David L. Mandel 8/4/2019 10:12:08 PM(UTC)
Kenmore Elite Washer lost cycle control (Washer Repair)
by Lion8360 11/23/2015 7:31:56 AM(UTC)
Kenmore Elite Washer Oasis HE (Washer Repair)
by Charlese 8/17/2015 11:15:49 AM(UTC)
Kenmore Elite Washer Possible Motor/Transmission/Gearcase Problem (Washer Repair)
by USCgEEk 8/16/2015 10:03:26 PM(UTC)
Kenmore Elite washer tripping breaker after it fills up. (Washer Repair)
by ElleG79 3/17/2015 3:21:13 PM(UTC)
Kenmore Elite washer will drain but does not agitate. (Washer Repair)
by thellamattina 12/3/2014 3:44:17 PM(UTC)
kenmore elite washer dl code in spin cycle (Washer Repair)
by THE FIXER 9/7/2014 7:01:57 PM(UTC)
Kenmore Elite washer not draining or spinning (Washer Repair)
by cadrin16 3/24/2014 10:54:33 AM(UTC)
Help identify part Kenmore Elite Washer - sort of a "clevis pin" (Washer Repair)
by rsaritzky 1/27/2013 7:40:45 AM(UTC)
Kenmore Elite Washer Not Changing Cycles (Washer Repair)
by maxruby 1/20/2013 5:23:05 PM(UTC)
Kenmore Elite washer agitates OK for 10 sec, then stops (Washer Repair)
by wodag 11/20/2012 9:35:19 AM(UTC)
Kenmore Elite Washer (Washer Repair)
by stirmon 10/27/2012 1:18:09 PM(UTC)
