Juniors
#1 Posted : Thursday, March 20, 2008 4:38:05 AM(UTC)
Juniors
What is the easiest shortcut to replace the "tub suspension pads"?
#2 Posted : Thursday, March 20, 2008 5:00:11 PM(UTC)
Nothing is easy in this life!
That's what you have to do:
1. Remove the cabinet from the washer.
2. Remove the pump and the motor.
3. Disconnect the wiring harness from the motor.
4. Disconnect the tub outlet hose from the tub.
5. Lift the entire tub, basket and tub support out as one unit.
Here are the break down diagrams for the Whirlpool washer Model LLR6144BQ1
washer vibrates on spin cycle only (Washer Repair)
by ronald.reifsteck@comcast. 8/29/2017 8:19:23 AM(UTC)
Washer vibrates violently (Washer Repair)
by 82pontiac 2/18/2017 5:40:36 PM(UTC)
Roper washer vibrates bad (Washer Repair)
by smessner 1/27/2014 6:18:31 PM(UTC)
Washer Vibrates and tub leans to the right-front (Washer Repair)
by squiggy711 6/29/2013 4:43:18 PM(UTC)
Maytag Performa Washer vibrates and walks (Washer Repair)
by Kurt_washer_2012 12/2/2012 5:54:40 PM(UTC)
Whirlpool Duet washer vibrates (Washer Repair)
by WhirlpoolAllen 6/6/2012 5:01:49 PM(UTC)
Whirlpool washer vibrates and walks (Washer Repair)
by Tom S. 2/27/2012 3:09:23 PM(UTC)
washer vibrates during fast spin cycle (Washer Repair)
by pclaypool09 10/11/2011 8:45:10 AM(UTC)
Siemens washer vibrates (Washer Repair)
by Robquin 7/7/2011 12:23:29 AM(UTC)
Washer Vibrates in spin cycle (Washer Repair)
by wbroadw 1/7/2011 12:32:20 PM(UTC)
maytag washer vibrates in spin when empty (Washer Repair)
by allan3367 12/14/2009 5:40:20 PM(UTC)
washer vibratesat end of spin cycle (Washer Repair)
by kgc159 11/23/2009 9:39:47 AM(UTC)
washer vibrates at end of spin cycle (Washer Repair)
by kgc159 11/23/2009 8:22:05 AM(UTC)
Washer Vibrates (Washer Repair)
by MellowMan 11/10/2009 1:47:49 AM(UTC)
washer vibrates and jumps during spin cycle (Washer Repair)
by chase29 6/17/2009 9:18:47 AM(UTC)
