amcarrejo
#1 Posted : Tuesday, March 18, 2008 3:22:32 AM(UTC)
amcarrejo
Last time I used my broiler, a small fire ignited. Since then, my oven won't light. Burners work fine, just the oven and broiler. Can I fix myself?
Thanks,
#2 Posted : Tuesday, March 18, 2008 4:27:11 PM(UTC)
Remove the oven floor and the flame spreader.
Check for 120VAC to the oven igniter (#19 on the burners break down diagram) while the oven thermostat calls for heat.
If there is 120VAC then the igniter is bad and has to be replaced.
If there is no 120VAC then replace the oven thermostat.
- The part number for the oven igniter is AP2150412
- The part number for the oven thermostat is AP2124416
Here are the break down diagrams for the Tappan range Model MGF334BGDD
amcarrejo
#3 Posted : Tuesday, March 18, 2008 10:05:07 PM(UTC)
amcarrejo
What does "Check for 120VAC to the oven igniter" mean?
Thanks for your help
oven wont light when i hit the bake button (Oven Repair (including Ranges and Cooktops))
by ern1luv 1/4/2012 3:03:59 PM(UTC)
Oven wont light, already replaced spark module (Oven Repair (including Ranges and Cooktops))
by bignmoval 6/8/2011 5:12:58 PM(UTC)
broiler and oven wont light (Oven Repair (including Ranges and Cooktops))
by berniebing 9/3/2010 6:44:43 AM(UTC)
oven wont light correctly (Oven Repair (including Ranges and Cooktops))
by nicehitsam 6/27/2010 5:05:42 PM(UTC)
by mruggieri 2/3/2010 2:22:08 PM(UTC)
by tmg1 6/17/2009 3:02:48 PM(UTC)
GE Gas Stove broiler works but oven wont light (Oven Repair (including Ranges and Cooktops))
by dunndec 1/27/2009 2:50:30 PM(UTC)
Oven wont Light (Oven Repair (including Ranges and Cooktops))
by Higgs 1/3/2009 1:17:01 PM(UTC)
Oven wont light, broiler will, eventually (Oven Repair (including Ranges and Cooktops))
by Lenty98 12/5/2008 3:40:21 PM(UTC)
