Inner glass on oven dooor is cracked/broken. need to replace. I believe p/n for glass is : AP4282886. Unsure is additional parts i.e oven door pad and liner, gasket, etc are needeed to complete job and if glass p/n is inner glass or outer glass. Advice appreciated
The model number you posted does not come up. Verify and repost it.
Posted incorrect Model Number for oven. Correct Model # ARG7600WW
Originally Posted by: Gene Thanks for your help, much appreciated. part # you listed is different from one listed at site when I placed order. Appliance Parts Pro listed part as AP4282886.
Originally Posted by: Mike-mcd ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for your help, much appreciated. part # you listed is different from one listed at site when I placed order. Appliance Parts Pro listed part as AP4282886. Actually there are two part numbers listed and in such situation you had to call the customer service to verify the correct part number. Gene.
