10 Pages<1234>»
johnyy664
#11 Posted : Sunday, March 8, 2009 12:35:35 PM(UTC)
johnyy664
Had the same problem - This posting solved the problem for me!
Misc
DiggerW
#12 Posted : Saturday, June 27, 2009 5:38:23 PM(UTC)
DiggerW
Gene did point this out, but I wanted to clearly add:
I had the same problem and identified to be a problem not with the Electronic Oven Control, but with *the power source to the oven.*
I don't know a good way for a non-electrician to confirm you're getting the 220V you're supposed to -- in my case, the sparks coming out of the makeshift duct-taped extension cord when I kicked it were a solid indicator. :mad:
fitkoc
#13 Posted : Wednesday, January 20, 2010 4:48:58 PM(UTC)
fitkoc
hi there, we have a 2 year old frigidaire ES510L Electric Range, all of a sudden the oven only reaches half of the temperature requested, would this be the same issue, the EOC, so basically the computer that controls and sets the oven temp? the top elements work fine, if we used convection would that be affected as well by the EOC not working properly. appreciate your help - i will miss my oven every single day!
fitkoc
#14 Posted : Wednesday, January 20, 2010 4:50:23 PM(UTC)
fitkoc
:o hi there, we have a 2 year old frigidaire ES510L Electric Range, all of a sudden the oven only reaches half of the temperature requested, would this be the same issue, the EOC, so basically the computer that controls and sets the oven temp? the top elements work fine, if we used convection would that be affected as well by the EOC not working properly. appreciate your help - i will miss my oven every single day!
#15 Posted : Wednesday, January 20, 2010 6:03:58 PM(UTC)
The model number you posted does not come up. Verify and repost it.
fitkoc
#16 Posted : Thursday, January 21, 2010 5:30:25 PM(UTC)
fitkoc
sorry Gene, it's model FEFLZ87GCA, s/n BF74946804. Is this easy to fix, could a normal guy fix and replace?
#17 Posted : Friday, January 22, 2010 11:55:28 AM(UTC)
The first thing you may want to do is check the oven temperature probe (#37 on the diagram) resistance. The normal resistance suppose to be about 1100 Ohms at the room temperature. You have to have a simple ohmmeter in order to do it.
Post the result.
Iris Whitehead
#18 Posted : Thursday, October 28, 2010 1:26:23 PM(UTC)
Iris Whitehead
I have the same problem as the person above. I was using the oven on bake last Easter and the oven made a popping sound and went off. I assumed the bake element went out. I have model #FED355EBA, it's only 4 years old. The oven element costs around $100 so I had to wait until 10/27 to order it and received today, put it in, and the oven still doesn't work. Please advise ASAP. I need my oven Sat. Thanks. Iris Whitehead
jsw9674
#19 Posted : Friday, December 31, 2010 5:53:24 AM(UTC)
jsw9674
Most likely the problem is a bad Electronic Oven Control (EOC) which has to be replaced.
- The part number for the EOC is AP3215567
Gene,
I have a similiar problem and it sounds like the EOC needs to be replaced. I heard a pop and the stove works, but not the oven.
Is this something I should be able to replace myself (as I'm fairly handy) and should I go through specific checks before purchasing the EOC? Also, any advice on what to do/not do when replacing the EOC?
Thank you for your time.
Jim
mcdowell_112
#20 Posted : Monday, January 31, 2011 3:06:50 PM(UTC)
mcdowell_112
I have a frigidaire range unit it will call for bake and broil but will not heat is the board bad?model #FEF326BB.The top elements work fine and I have power coming to the left side of elements but not on the right side.
Guest (6)
10 Pages<1234>»
