handypete
#1 Posted : Tuesday, March 18, 2008 7:05:24 AM(UTC)
handypete
The washer fills and agitates but will not drain. Multiple cycle settings (perm press, handwash, etc.) all have the same problem. I suspect the pump - but don't want to replace if it is something else. Is there an easy test for pump failure?
Thanks for any suggestions.
roycreamer
#2 Posted : Tuesday, March 18, 2008 3:12:41 PM(UTC)
roycreamer
if it spins, you probably have something stuck in the pump, or the hose that comes from the tub to the pump.
handypete
#3 Posted : Wednesday, March 19, 2008 9:47:59 AM(UTC)
handypete
Thank you for the suggestion. I'll check that.
