2 Pages12>
MrSandoval
#1 Posted : Wednesday, December 10, 2008 4:33:47 PM(UTC)
MrSandoval
:confused: Our washer completes the wash cycle but will not completely drain out rinse water, leaving our clothes sopping wet. There is also water left somewhere within and leaves behind a funky odor.:eek: Any help will be greatly appreciated!
libertyappl
#2 Posted : Wednesday, December 10, 2008 4:39:15 PM(UTC)
libertyappl
Check your pump for an obstruction.
As for the funky smell.... do you use liquid detergent and/or fabric softener? Have you performed the recommended bleach cycle, with nothng else once per month?
Nat
richappy
#3 Posted : Thursday, December 11, 2008 1:30:36 AM(UTC)
richappy
If nothing stuck in the pump, I would time how long it takes to drain all the water, if well over 30 seconds, replace the pump.
#4 Posted : Thursday, December 11, 2008 3:34:51 AM(UTC)
Here is your parts breakdown
Model MAH5500BWQ
And a service manual
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
As for the skunk many people swear by Affresh
Washer Parts - Order Now, Same Day Shipping
Chuck Thompson
#5 Posted : Thursday, December 11, 2008 5:06:38 AM(UTC)
Chuck Thompson
I have exactly the same problem as you. It doesn't make sense that the pump would be bad because it clears the wash water. I am leaning to either the lid switch or the timer. I'll let you know.
ronei
#6 Posted : Monday, January 18, 2010 1:05:26 PM(UTC)
ronei
i also have the same problem, the pump sucks the water to slow and my clothes stay too wet.. need help. already check up the pump and there is anything blocking the water pass....
richappy
#7 Posted : Tuesday, January 19, 2010 12:17:06 AM(UTC)
richappy
We are talking about a front loader here. For the front loader, you might not have high spin at all. Check the motor control board for that. If top loader, check the clutch,especially if it fails to spin with a heavy load.
ronei
#8 Posted : Tuesday, January 19, 2010 3:09:09 PM(UTC)
ronei
my washer is a frigidaire model: fleb43rgs1 . I think the pump is draining too slow...nothing is stucking the pump....what could it be?
richappy
#9 Posted : Wednesday, January 20, 2010 12:19:41 AM(UTC)
richappy
You just may have a bad pump. If you turn the washer timer back to spin and the rest of the water drains out, you have a bad pump, should clear out all the water in spin period.
ronei
#10 Posted : Saturday, January 23, 2010 9:01:54 PM(UTC)
ronei
i bought a new pump and installed it. it worked for a little while but now it is not pumping the water .the machine spins but no water coming out from the hose ...i also bought a new washer time control. now i dont know what to do...this machine is driving me crazy ......
GE Profile Dishwasher will not drain completely (Dishwasher Repair)
by michellemb 1/5/2011 8:05:52 AM(UTC)
Washer will not drain completely, and has a banging noise when it does spins (Washer Repair)
by IVETTE 8/19/2010 11:54:45 PM(UTC)
Maytag Dishwasher will not drain completely! (Dishwasher Repair)
by dahilife 8/9/2010 8:43:50 AM(UTC)
by rwaltd 4/2/2009 11:05:59 AM(UTC)
by 2bluesuz 3/23/2009 2:28:34 PM(UTC)
2 Pages12>
