4 Pages<1234>
todd99
#11 Posted : Monday, December 8, 2008 5:42:51 PM(UTC)
todd99
Hi gene,
I am having the same problem with a model RS675PXGQ0 drop in oven. Do you know what the part number is and the location of it on this model? Thanks
#12 Posted : Tuesday, December 9, 2008 12:52:23 PM(UTC)
todd99,
The thermal fuse (#37 on the break down diagram) is located on the back of the range, behind the rear panel.
- The part number for the thermal fuse is AP3885687
Here are the break down diagrams for the Whirlpool range Model RS675PXGQ0
#13 Posted : Tuesday, December 9, 2008 1:02:20 PM(UTC)
Hi Tami,
Sorry for the delay. The oven is not heating due to a bad thermal fuse on the back of the oven (#37 on the break down diagram). Some time this part called "thermostat", so maybe your tech meant the same part under the different name. In order to replace it the oven has to be removed from the cabinet. The problem with the control and the display does not look clear to me. I would recommend to replace the thermal fuse first and see how it will work.
Here are the break down diagrams for the Whirlpool oven Model GBS277PDQ1
Eric91390
#14 Posted : Monday, January 18, 2010 12:50:35 PM(UTC)
Eric91390
Hello Gene,
I have a Whirlpool Gold electric oven model GBS307PDQ1, which I have not seen discussed here.
Can I get the part number for the thermal fuse?
Also a link to the breakdown diagram?
Can I get the fuse at a home-improvement store, hardware store or appliance store maybe?
Eric
#15 Posted : Wednesday, January 20, 2010 1:12:43 AM(UTC)
Quote:
...Can I get the part number for the thermal fuse?...
- The thermal fuse Part number: AP3885687
Quote:
...Also a link to the breakdown diagram?...
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GBS307PDQ1 | AppliancePartsPros.com
Quote:
...Can I get the fuse at a home-improvement store, hardware store or appliance store maybe?...
You can get it through appliance parts store only or you can order it from this site.
You can find more information in one of our previous posts: http://forum.appliancepartspros...ba-double-oven-help.html
Robiolo
#16 Posted : Wednesday, January 27, 2010 2:33:49 PM(UTC)
Robiolo
Self clean just killed my rs696pxeq2. Before I replace the thermostat though, I see that pushing the top (up) temperature arrow (or the down arrow) makes the temperature go down, not up. Does this indicate an additional problem?
Also, if I intend to jigger the oven lock so that I can use self clean to bake pizzas at high temperature, will this keep happening? Is there a way to prevent it from blowing all the time? Thanks.
#17 Posted : Wednesday, January 27, 2010 6:57:34 PM(UTC)
Originally Posted by: Robiolo Go to Quoted Post
1) Self clean just killed my rs696pxeq2. Before I replace the thermostat though, I see that pushing the top (up) temperature arrow (or the down arrow) makes the temperature go down, not up. Does this indicate an additional problem?
2) Also, if I intend to jigger the oven lock so that I can use self clean to bake pizzas at high temperature, will this keep happening? Is there a way to prevent it from blowing all the time? Thanks.
1) Yes, it does. Most likely the problem is a bad control panel. The white control panel is no longer available, but the black panel is still available.
2) The best way to prevent the thermal fuse from blowing is not to use the self clean and, using the self clean for cooking can cause fire.
- The control panel Part number: AP3030832
- The oven thermal fuse Part number: AP3885687
markarin
#18 Posted : Thursday, January 28, 2010 6:13:50 PM(UTC)
markarin
...we have a Whirlpool RBS307PVS that now also fails to heat after we ran it through the self-cleaning cycle. Would you be so kind as to point me in the right direction for the thermal fuse part number and diagrams?
Thank you for all you do!!!
#19 Posted : Thursday, January 28, 2010 7:19:54 PM(UTC)
The thermal fuse for your oven is shown as #30 on the diagram. The oven has to be removed from the cabinet to access the part.
whirlpool123
#20 Posted : Wednesday, February 3, 2010 1:24:36 PM(UTC)
whirlpool123
Hi gsran,
Most likely the problem with you oven is an open thermal fuse on the back of the oven. You have to remove the oven from the cabinet and remove the back cover from the oven to access the part.
Gene,
I have a 4 year old Whirlpool electric double oven model #RBD245PDB15 with the same problem. My father-in-law checked the fuses according to the diagnostic manual in the oven & all fuses seemed to be ok. Can they test ok & still be blown? Some other blogs seem to indicate it could be the control panel assembly with membrane switch or the electronic clock control board. What are your thoughts? Thanks!
Guest (11)
4 Pages<1234>
