JennaLogan
#1 Posted : Friday, January 15, 2010 6:34:36 AM(UTC)
JennaLogan
Hello,
I have a Whirlpool Accubake Oven, Model # WGP_4800 (I cannot read the middle digit) and it keeps beeping randomly and displaying F2 on the screen. I was told that F2 meant a faulty heat sensor, so I purchased a new one and installed it. The oven now heats up to temperature, but then shuts off and still displays F2. It also beeps each time the door is opened and each time an element gets turned on. Any ideas??
Thanks,
Jenna
#2 Posted : Friday, January 15, 2010 5:59:39 PM(UTC)
Jenna,
Measure the oven temperature sensor resistance at the control board plug. It suppose to be about 1100 Ohms at the room temperature.
If the reading is good, the control board has to be replaced. Without the complete model number it's very hard to find the correct part number.
If the reading is wrong, proceed to the sensor plug on the back of the range and measure the resistance at that plug.
If the reading is still wrong, the sensor is bad.
If the reading is correct, eliminate the sensor plug and reconnect the sensor wires, using a high temperature porcelain wire nuts.
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
F3 then F2 error code on Whirlpool Oven (Oven Repair (including Ranges and Cooktops))
by Ed070811 11/10/2013 9:23:56 AM(UTC)
f2 error code while self cleaning (Oven Repair (including Ranges and Cooktops))
by sandyg 5/12/2013 2:35:23 PM(UTC)
F2 Error code (Oven Repair (including Ranges and Cooktops))
by ccfox 7/25/2012 12:51:03 PM(UTC)
Whirlpool F2 Error code. (Oven Repair (including Ranges and Cooktops))
by polk5295 3/29/2012 6:32:11 PM(UTC)
F2 error code (Oven Repair (including Ranges and Cooktops))
by DYB 3/19/2012 1:39:19 PM(UTC)
E1 F2 error code Kitchen aid biltin oven (Oven Repair (including Ranges and Cooktops))
by fredcroy 12/6/2011 2:19:31 PM(UTC)
E6 F2 error codes (Oven Repair (including Ranges and Cooktops))
by tom o 11/30/2011 6:37:15 AM(UTC)
f2 error code (Oven Repair (including Ranges and Cooktops))
by szawackitx 6/15/2011 7:46:39 PM(UTC)
Kitchenaid range f3 and f2 error codes (Oven Repair (including Ranges and Cooktops))
by shane1 5/24/2011 6:44:04 PM(UTC)
kenmore microwave has f2 error code (Washer Repair)
by bobval 4/29/2011 6:00:09 PM(UTC)
Please Help!! E6 and F2 Error Codes (Oven Repair (including Ranges and Cooktops))
by mlindsey3418 11/16/2010 1:27:25 PM(UTC)
E0 F2 error code (Oven Repair (including Ranges and Cooktops))
by carapet58 11/14/2010 1:33:19 PM(UTC)
E6 F2 error code for Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by ddelay 1/2/2010 12:06:19 PM(UTC)
F2 error code (Washer Repair)
by kayakcrzy 10/20/2009 3:04:24 PM(UTC)
