LaTrelle
#1 Posted : Wednesday, January 13, 2010 7:23:01 AM(UTC)
LaTrelle
This microwave oven has, over the past several months, gradually lost power and taken longer and longer to attain a given heat level. I believe it to be the Magnetron failing and needing to be replaced. What is your opinion?
Also, I have pulled the microwave out and gone into it, but can't figure out how to get the present magnetron out.
Would appreciate any advice you may have.
#2 Posted : Wednesday, January 13, 2010 4:23:53 PM(UTC)
Remove the microwaves outer case. The magnetron secured with the four screws. The thermal protector (#28 on the diagram) has to be removed from the old magnetron and installed on the new one, exactly at the same location.
- The magnetron Part number: AP3109456
