mbryans
#1 Posted : Thursday, January 7, 2010 12:31:19 PM(UTC)
mbryans
My dryer suddenly stopped working. I can tell there is power and I can hear the timer making a clicking sound, but the dryer will not turn on. I have already replaced the on/off switch but this did not work. Any other thoughts?
#2 Posted : Thursday, January 7, 2010 5:39:11 PM(UTC)
Check for continuity between the "BK" & "BU" and the "T" & "W" timer terminals while the timer in "ON" position. Post the results.
Here is the Wiring sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGQ7030KQ1 | AppliancePartsPros.com
mbryans
#3 Posted : Friday, January 8, 2010 9:32:38 AM(UTC)
mbryans
ok I tested as you recomended with the following results:
"BK" and "BU" showed no reading with the timer set to "ON".
With the timer off I got as reading of 120V
"T" and "W" showed no readings at all.
Also on a recomendation I took the initiative to change the thermal fuse and the problem still exists.
#4 Posted : Friday, January 8, 2010 4:02:58 PM(UTC)
Quote:
...With the timer off I got as reading of 120V...
Did you run a continuity test?
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
mbryans
#5 Posted : Saturday, January 9, 2010 4:31:33 AM(UTC)
mbryans
okay thanks my bad.
I switched the meter to ohms and got the following:
With the timer on
"BK" "BU" read 0
"T" "W" gave me a negative number which was jumping all over
With the timer off:
"BK" "BU" read negative numbers around 180
"T" "W" read 0
mbryans
#6 Posted : Monday, January 11, 2010 5:01:29 PM(UTC)
mbryans
Hi Gene, just wondering if you have any thoughts on the latest? I'm still wondering what could be causing this???
Originally Posted by: mbryans Go to Quoted Post
okay thanks my bad.
With the timer on
"BK" "BU" read 0
With the timer off:
"T" "W" read 0
#7 Posted : Monday, January 11, 2010 6:05:56 PM(UTC)
Have you unplug the dryer prior to the test?
A negative numbers on Ohms scale sounds weird.
mbryans
#8 Posted : Monday, January 11, 2010 7:10:10 PM(UTC)
mbryans
I unplugged the unit and retested.
BK-BU read 0
T-W read 1 on the meter which was unchanged from where it started.
#9 Posted : Thursday, January 14, 2010 7:05:32 PM(UTC)
BK-BU read 0
These results show that there is probably nothing wrong with the timer. You said earlier that you replaced the on/off switch. Which part did you mean? Can you use the reference number from the diagram?
mbryans
#10 Posted : Sunday, January 17, 2010 3:39:05 PM(UTC)
mbryans
It would have been Item# 39 on the diagram for the Top and Console.
Guest (5)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Whirlpool Dryer will not start, have power "sensing light is on" Replaced both thermi (Dryer Repair)
by joanu 11/21/2013 6:32:09 AM(UTC)
Whirlpool dryer will not start (Dryer Repair)
by vaughn quern 11/26/2012 9:52:02 AM(UTC)
by vaughn quern 11/26/2012 9:44:09 AM(UTC)
whirlpool dryer will not start (Dryer Repair)
by mikeshard 3/29/2012 8:49:17 PM(UTC)
Whirlpool dryer will not start. (Dryer Repair)
by c33341 3/11/2011 9:47:28 AM(UTC)
by Newglide 1/12/2011 6:54:14 PM(UTC)
by dafense 2/10/2010 6:13:16 PM(UTC)
by rsqmedic8 7/26/2009 7:43:08 AM(UTC)
by bratsinc4 2/4/2009 6:05:06 PM(UTC)
