I have a kenmore 80 that thumps every so often on spin allmost sounds like gears stripping or springs poping. I allready had the gear box apart and found some worn teeth but none missing or broken it didnt seem like it was the problem. The spanner nut was tight on the shaft. any ideas my wife is going 2 kill me if i dont get this thing fixed
I would recommend to replace the gear case. Also check the suspension. - The part number for the gear case is AP3096209 Gene.
