3 Pages<123>
washer
#11 Posted : 17 years ago
washer
This one woke me up to GE quality. A relatively new, builder installed GE dishwasher started leaking from the right side. Even though it was keeping my tile grout clean I opted for a new dishwasher (not GE). When I removed the machine the cause of the leak became clear. The body of the machine was bowed outward making it impossible for the door gasket to seal properly. Isn't that a beaut?
Don Evans
#12 Posted : 17 years ago
Don Evans
Good Morning Gene,
The tip that you gave me was right on the money. I didn't have to change the latch, my problem was that we were not closing the detergent door when we started the wash cycle.
Don Evans
Don Evans
#13 Posted : 17 years ago
Don Evans
Hi Gene,
I'm sorry for the confusion. I took the inner side of the door off and the soap dispenser appears to be working properly. The dishwasher is actually leaking on the left side not the right. I tighten all of the screws pretty tight when replacing the door, however more water seems to be comming out now then before.
Don Evans
#14 Posted : 17 years ago
Hi Don,
Check the vent screen (#12 on the inner door break down diagram) for any blockage.
Inspect the door gasket.
richappy
#15 Posted : 17 years ago
richappy
Open the door while the dishwasher is running. See if the wash arm is spraying sideways from a split spray arm. Also, check to see if the dishwasher is over filled.
santongiorgi
#16 Posted : 17 years ago
santongiorgi
I have a Kenmore dishwasher, mod. 363.1517000, that leaks when it is rinsing. I believe it is leaking from the bottom. It's around 6 years old. Any advice?
#17 Posted : 17 years ago
Hi santongiorgi,
Remove the bottom panel and check where exactly it's leaking from.
Post your findings.
MarkSpencer1
#18 Posted : 17 years ago
MarkSpencer1
Whirlpool du810dwgui 1999 model leaking bottom right corner thru the door. I replaced door seal already, disassembled door and cleaned hard water deposits, do not see anything "broke".
When I stuff a little cloth inside door at bottom/end of door seal, water leak stopped. only work around though. Leak is mainly when start washer, water seems to squirt.
Mark
#19 Posted : 17 years ago
Hi Mark,
Remove the inner door panel and check for a leak through the latch (#3 on the inner door break down diagram).
Here are the break down diagrams for the Whirlpool dishwasher Model DU810DWGU1
MarkSpencer1
#20 Posted : 17 years ago
MarkSpencer1
I checked for leak at latch, no leak there.
As soon as the water starts going into the dishwasher, the water squirts out the bottom right corner.
After I checked the latch for leak and reassembled the door, I turned the dishwasher on, the inlet water shoots from the left side across the dishwasher into the corner where the water leaks.
I immediately opend the door, the inside of the door was still dry up by the latch.
I cleaned all the hardwater deposits off the door prior to this test.
The inlet water opening is clean with no mineral deposits.
HELP! -------Thank YOU!
LG LDF7774ST leaking dishwasher (Dishwasher Repair)
by corvets 5 years ago
Leaking Dishwasher (Dishwasher Repair)
by theflanigans 10 years ago
Non-Handy Woman + Leaking Dishwasher = DISASTER (Dishwasher Repair)
by cbrennan 11 years ago
Leaking Dishwasher (diverter motor) (Dishwasher Repair)
by rmsmith 13 years ago
by mljoecks 13 years ago
by clints 15 years ago
by pdl 15 years ago
by macnlrc 15 years ago
Leaking dishwasher (Dishwasher Repair)
by Brucefamily 16 years ago
by tammyneedshelp 16 years ago
by EMHBARMAN 17 years ago
by warrenjr 17 years ago
by verne k 17 years ago
Leaking dishwasher door (Dishwasher Repair)
by flowboard 17 years ago
3 Pages<123>
