AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Ge spacesaver heats but intermitten turntable and light operation
The heats food without the turntable or light. Either both come on or stay off. What controls them? Please help. km
The lights and turntable in your microwave controls by the main control board (#12 on the diagram). There is a wiring diagram behind the top grill. Locate and check the wire harness plug on the control board which goes to the lights and turntable and make sure there is a good connection. If there is nothing wrong, replace the control board. - The control board Part number: AP2631591
Originally Posted by: Gene The lights and turntable in your microwave controls by the main control board (#12 on the diagram). There is a wiring diagram behind the top grill. Locate and check the wire harness plug on the control board which goes to the lights and turntable and make sure there is a good connection. If there is nothing wrong, replace the control board. - The control board Part number: AP2631591
Thank you so much Gene.
Gene, I went to the microwavedisplay.com site or Microwave oven display repair by mail site. Read it. Called and spoke to William E. Miller at 11 N. Washington st. Anderson Indiana. 765-378-4640. I removed the entire control panel and sent it 01/11/10 with the required $39.95. I've received no confirmation, I cannot reach anyone and my check has been processed. I think I've been snookered. Don't know what to do. Suggestions? Thanks, Ken
Microwave Repair
